Question
  • Products
  • Encyclopedia
  • Buy offers
  • Suppliers
Home >50-00-0>Q&A>Haloperidol synthesis - 1-chloro-4-(prop-1-en-2-yl)benzene with NH4Cl and formaldehyde
Answer Follow +1
Tandy Answered Jul 28 2021
However I have no idea how the first two steps work. Especially the first step makes me wonder how the amine and the aldehyde form the 1,3-oxazinane.
enter image description here
Suggestions: Ammonia and formaldehyde form via condensation the imine. The imine and formaldehyde form the 1,3-oxazinane, however I looks kinda wrong to me. Moreover, if this is mechanism would be correct, why does the formaldehyde binding to prop-1-en and the imine don't?
Step 2 probably starts with protonating the oxygen and i think the 1,3-oxazinane cleavage follows after. However how does the methyl group bonds with the other methylene group?
50-00-0 Related Q&A
Lastest Questions
Encyclopedia
Haloperidol CAS No: 52-86-8 MF: C21H23ClFNO2
Appearance Clear, colorless solution with no odor.
Density 1.3 (20 C)
Melting Point 152 °C
Boiling Point 529
Vapour 4.8X10-11 mm Hg @ 25 deg C /Estimated/
Flash Point 274
Solubility 14 mg/L
Color/Form white
Stability Stable at normal temperature and pressure.
HS Code 2933399090
Storage temp Keep in a cool, dry, dark location in a tightly sealed container or cylinder. Keep away from incompatible materials, ignition sources and untrained individuals. Secure and label area. Protect containers/cylinders from physical damage.
Formaldehyde CAS No: 50-00-0 MF: CH2O
Appearance colorless gas
Density 1.083
Melting Point -15℃
Boiling Point 97℃
Vapour greater than 1 atm (NIOSH, 2016)
Refractive Index 1.3755-1.3775
Flash Point 60℃
Solubility soluble in water
Color/Form Nearly colorless gas [Note: Often used in an aqueous solution]. /Pure formaldehyde/
Stability On standing, especially in the cold, may become cloudy, and on exposure to very low temperature ppt of trioxymethylene formed; in air it slowly oxidizes to formic acid /40% solution/.
HS Code 29121100
Storage temp 2-8°C
formaldehyde CAS No: 53026-80-5 MF: CH2O
Density 1.083
Melting Point -15℃
Boiling Point 97℃
Flash Point 60℃
Storage temp 2-8°C
52-86-8 Related Suppilers
  • 1YR CANGZHOU ENKE PHARMA-TECH CO.,LTD Country/Region:China Product Name:Haloperidol Update Time:Sep 28 2021 Main products:Cangzhou Enke Pharma-tech Co.,Ltd (China) is a leading manufacturer of innovative chemistry products and services throughout the pharmaceutical R&D process and commercial production. Inquire
  • 5YRS SN Biotechnology co. LTD Country/Region:United States Product Name:Haloperidol Update Time:Jul 15 2021 Main products:Chemicals,Drugs ,Blotter ,Pill,Raw... Inquire
  • 1YR Amitychem Corporation Country/Region:China Product Name:Factory Supply Haloperidol Update Time:Mar 09 2021 Main products:Manufacture & Supply Biopharm Chemical, Specialty Chemical, PetroChemical. Inquire
  • 10YRS Hangzhou Dayangchem Co., Ltd. Country/Region:China Product Name:Haloperidol Update Time:Dec 20 2019 Main products:Chemical products Inquire
