Question
  • Products
  • Encyclopedia
  • Buy offers
  • Suppliers
Home >50-00-0>Q&A>How many moles of oxygen are required to react with methanol in order to produce 20 moles of formaldehyde?
Answer Follow +1
Napier Answered Dec 10 2021
I think the mile is mole
Let's consider the reaction between methanol and oxygen, then compare the mole ratios
CH3OH + ½O2 => CH2O + H2O.
The mole of CH2O to O2 is 1 : ½
20 moles of CH2O = 1/2 x20 = 10 moles of O2
The moles of oxygen required is 10 mol
Edward Answered Dec 10 2021
I am assuming that ‘miles’ is a typo and the question should read ‘How many moles …’. If so then first, one needs to know the equation for this process. I believe that in this reaction, hydrogen peroxide (H2O2) is also formed so
CH3OH + O2 → CH2O + H2O2
The ratio of methanol (CH3OH) to formaldehyde (CH2O) is 1:1 so you will need 20 moles of methanol to get 20 moles of formaldehyde. Further, the ratio of formaldehyde to oxygen (O2) is also 1:1, so you will need 20 moles of oxygen to get 20 moles of formaldehyde. There is a caveat, the numbers assume the reaction gives 100% yield.
Edit
If the reaction I wrote above was the correct one, then the answer I gave is fine. However, as Lloyd Brown points out, the correct reaction is
CH3OH + 1/2 O2 → CH2O + H2O
or
2 CH3OH + O2 → 2 CH2O + 2 H2O
So the ratio of O2:CH2O is 1:2 so to get 20 moles of CH2O, you will need 10 moles of O2.
Zandra Answered Dec 10 2021
2CH3OH(g) + O2(g) → 2CH2O(g) + 2H2O(g)
The mole ratio of oxygen to formaldehyde is 1:2 as scene in the balanced chemical equation. To make 20 moles of CH2O requires 10 moles of O2.
Clearly, you can do this in your head or you can set up the conversion factor.
20 mol CH2O x (1 mol O2 / 2 mol CH2O) = 10 mol O2
50-00-0 Related Q&A
  • Does melamine have formaldehyde? Yes! melamine has formaldehyde. Melamine resin with melamine rings is terminated with multiple hydroxyl groups and these are derived from formaldehyde.
  • How do I test for formaldehyde in the air? Just being simple. Working on the same principle, the classical chromotropic acid spot test method of formaldehyde detection has been quantified to find out the formaldehyde content of water at trace level with no trouble. Chromotropic acid is the most widely used reagent for formaldehyde analysis ...
  • How do I calculate ppm of vapor generated of formaldehyde in batch that starts out at room temperature but then is elevated to 350F during batch? I would be surprised to learn that a person with a Bachelor’s degree would be asking that question without at least giving the volume of the space where the paraformaldehyde is being de-polymerised. I would suggest that as somebody who has used formaldehyde as a decontaminant more times than I car...
  • Can hydrogen bonding occur in pure formaldehyde? Intermolecular hydrogen-bonding can occur when hydrogen is directly bound to a strongly electronegative element, viz. [math]O[/math] , [math]N[/math] , or [math]F[/math] … and this is NOT the scenario in formaldehyde, i.e. [math]H_{2}C=O[/math] …. the molecular is POLAR sure given the oxygen, but...
Lastest Questions
Encyclopedia
Formaldehyde CAS No: 50-00-0 MF: CH2O
Density 1.083
Melting Point -15℃
Boiling Point 97℃
Vapour greater than 1 atm (NIOSH, 2016)
Refractive Index 1.3755-1.3775
Flash Point 60℃
HS Code 29121100
METHANOL CAS No: 170082-17-4 MF: CH4O
Density 1.053 g/mL at 20 °C
Melting Point ?98 °C(lit.)
Boiling Point 64.7 °C(lit.)
Vapour 410 mm Hg ( 50 °C)
Refractive Index n20/D 1.329(lit.)
Flash Point 72 °F
HS Code 29051100
oxygen CAS No: 17410-58-1 MF: C22H22N2
50-00-0 Related Suppilers
  • 1YR hebei youze biotechnology Co.,Ltd Country/Region:China Product Name:Formaldehyde CAS 50-00-0 Methylene glycol Update Time:May 24 2022 Main products:biotechnology pharmaceutical intermediates biotechnology medical intermediates Inquire
  • 1YR Henan Kanbei Chemical Co.,LTD Country/Region:China Product Name:Formaldehyde Update Time:Apr 27 2022 Main products:chemical raw materials, veterinary drug raw materials, animal and plant extracts, pharmaceutical excipients, pharmaceutical products, food additives Inquire
  • 3YRS Hebei Yanxi Chemical Co.,Ltd Country/Region:China Product Name:Formaldehyde CAS NO.50-00-0 Update Time:May 24 2022 Main products:Division I, the main production Lead acetate phenylacetamide Cyromazine quality is very good! Inquire
  • 2YRS Hebei Crovell Biotech Co. Ltd Country/Region:China Product Name:Factory Supply Formaldehyde CAS 50-00-0 Update Time:May 05 2022 Main products:Cosmetic Raw Materials,solvents,etc. Inquire
