Question
  • Products
  • Encyclopedia
  • Buy offers
  • Suppliers
Home >7439-89-6>Q&A>How to prepare a solution of Ferrous Iron?
Answer Follow +1
Hampton Answered Apr 25 2022
I need to prepare a solution of Ferrous Iron (Fe2+). This solution will be used to test a water filtration system by simulating the Ferrous Iron that is sometimes present in well water. The system is supposed to convert the Ferrous Iron to Iron Hydroxide precipitate via a Manganese Oxide catalyst and filter it out.
What is the best way to get the Iron 2+ ions into the solution? I have seen suggestions to add Iron(II) Sulfate or Mohr's Salt. Something that is confusing me is that the Wikipedia articles for these compounds suggest they form a complex when dissolved in water. For Iron(II) Sulfate and Mohrs Salt the aquo complex [Fe(H2O)6]2+ is formed. I am wondering, are Iron(II) ions always in this aquo complex, and perhaps in some discussions of chemistry this fact is ignored for simplification? I question if the Iron 2+ ion will be available to participate in the reactions and get converted to Iron Hydroxide if it is in the aquo complex.
To summarize, what is the best way to make a solution with Fe 2+ ions that will simulate well water? And an explanation of the chemistry of the aquo complex formed by Mohrs salt and Iron(II) Sulfate and how that differs or is the same as a Fe 2+ ion alone in solution would be appreciated if someone is so inclined.
Thank you for sharing your knowledge!
7439-89-6 Related Q&A
  • Can we live without iron and aluminium? It would be extremely difficult, especially nowadays, but aluminium is relatively new to mankind and ancient e lived without iron. Aluminium was only discovered in 1825 by a Danish chemist.
  • What is the most stable state of an iron ion? The electron configuration of iron(Fe) is [Ar] 3d6 4s2 If iron release two electrons its form Fe^2+ ion and the electron configuration becomes as [Ar] 3d^6 Again to get more stability iron release another electron to form Fe^3+ ion. In this circumstances, the electron configuration of Fe^3+ becomes...
  • What is a goffering iron? “The goffering or 'tally' iron (the latter a corruption of 'Italian iron' after the country from which they were introduced in the early 17th century) was used to make ruffles, frills and flounces in starched linen. The barrel was heated by inserting a red-hot bar of iron like a poker. Goffering i...
  • Is iron in the brown ring compound in a +1 oxidation state? In the standard brown ring test for the nitrate ion, the brown ring complex is: [ F e ( H X 2 O ) X 5 ( N O ) ] X 2 + [ F e ( H X 2 O ) X 5 ( N O ) ] X 2 + In this compound, the nitrosyl ligand is positively charged, and iron is in a + 1 + 1 oxidation state. Now, iron has stable oxidation states +2...
Lastest Questions
Encyclopedia
Iron CAS No: 7439-89-6 MF: Fe
Density 7.86
Melting Point 1535℃
Boiling Point 3000℃
Vapour 1Pa at 1455 °C (solid); 10 Pa at 1617 °C; 100 Pa at 1818 °C; 1 kPa at 2073 °C; 10 kPa at 2406 °C; 100 kPa at 2859 °C
Flash Point >230 °F
HS Code 72052900
iron CAS No: 8053-60-9 MF: Fe
Melting Point 1,538 deg C
Boiling Point 2,861 deg C
iron CAS No: 39344-71-3 MF: Fe
7439-89-6 Related Suppilers
  • 1YR hebei youze biotechnology Co.,Ltd Country/Region:China Product Name:iron atom CAS 7439-89-6 iron bisaspartate/MFCD00010999 Update Time:Sep 22 2022 Main products:biotechnology pharmaceutical intermediates biotechnology medical intermediates Inquire
  • 2YRS Hebei Crovell Biotech Co. Ltd Country/Region:China Product Name:High Concentration Inorganic Salt Wastewater Treatment Carrier Boiler Water Treatment Chemical Update Time:May 05 2022 Main products:Cosmetic Raw Materials,solvents,etc. Inquire
  • 2YRS LUYUNJIA CHEMISTRY XIAMEN LIMITED Country/Region:China Product Name:Iron powder Update Time:Sep 29 2022 Main products:o-Phthalaldehyde, Methoxyammonium chloride. DMSO, NMP, Inquire
  • 11YRS Nanjing Chemlin Chemical Co., Ltd. Country/Region:China Product Name:Stainless steel powder Update Time:May 13 2022 Main products:bulk commodities, lab agents, intermediates & fragments, special chemicals, agro-chemicals, APIs, natural ingredients Inquire
