Question
  • Products
  • Encyclopedia
  • Buy offers
  • Suppliers
Home >1305-62-0>Q&A>What reaction happens when carboxylic acids are treated with calcium hydroxide and distilled? [closed]
Answer Follow +1
Ochoa Answered Aug 04 2021
Acetic acid (as an example of a typical carboxylic acid) reacts with calcium hydroxide to form calcium acetate. This is a simple acid-base reaction which forms a salt and water:
2CHX3COOH+Ca(OH)X2?(CHX3COO)X2Ca+2HX2O
Upon heating, calcium acetate undergoes decomposition to acetone and calcium carbonate. The acetone can be distilled off from the mixture, leaving behind solid calcium carbonate:
(CHX3COO)X2CaΔCaCOX3+2(CHX3)X2C=O
At even higher temperatures calcium carbonate itself can be decomposed to calcium oxide and carbon dioxide:
CaCOX3ΔCaO+COX2
References
  1. https://www.tut.fi/ms/muo/vert/3_organic_chemistry/carboxylic_reactions.htm
  2. http://www.docbrown.info/page04/OilProducts10.htm
1305-62-0 Related Q&A
  • Electrolysis of calcium hydroxide in glycerol [closed] Calcium hydroxide is probably slightly soluble in glycerine due to tight chelation of Ca++ ion by the three hydroxyls of (probably 2) glycerine(s). But the hydroxyls will be present too, and on hydrolysis, will yield O2 plus H2O. But beyond that, imagine you produce some calcium metal: it will be i...
  • Would magnesium and calcium hydroxide undergo a single replacement reaction? Can calcium hydroxide react with magnesium (if given sufficient activation energy) to produce magnesium hydroxide and calcium, in the same way that NaOH + M g ⟶ M g ( O H ) X 2 + N a " style="position: relative;" tabindex="0" id="MathJax-Element-2-Frame" class="MathJax" M g ? M g ( O H )...
  • Why does bubbling carbon dioxide through calcium hydroxide result in a precipitate? Why does the addition of carbon dioxide to calcium hydroxide create the precipitate calcium carbonate? What happens chemically for such a molecule to form? How exactly do their interactions come into play? Now CaOH isn’t terribly soluble in water but the parts that do dissolve, disassociate into t...
  • Is there an equilibruim in an unsaturated calcium hydroxide solution? Imagine an unsaturated(No Ca(OH) 2 (s) just Ca 2+ (aq) and OH - (aq) ) aqueous solution of Calcium Hydroxide. Is the following equilibrium present in that solution and does the transparency of an unsaturated Calcium Hydroxide vanish after a while? C a X 2 + X ( a q ) + 2 O H X ? X ( a q ) ? ? ? ? C...
Lastest Questions
Encyclopedia
Calcium hydroxide CAS No: 1305-62-0 MF: CaH2O2
Appearance white powder or colourless, slightly cloudy, aqueous solution
Density 2.24 g/mL at 25 ℃(lit.)
Melting Point 580℃
Boiling Point 2850℃
Vapour 0 mm Hg (approx) (NIOSH, 2016)
Refractive Index Index of refraction: 1.574 (alpha), 1.545 (beta)
Flash Point /Calcium Hydroxide is/ non flammable
Solubility 1.65 g/L (20 °C ) in water
Color/Form Crystals or soft granules or powder
Colorless, hexagonal
Rhombic, trigonal, colorless crystals
White powder
White powder [Note: Readily absorbs CO2 from the air to form calcium carbonate].
Stability Stable. Incompatible with strong acids.
HS Code 2825 90 19
Storage temp Store at RT.
Calcium CAS No: 7440-70-2 MF: Ca
Appearance softish silver-white metal
Density 1.54
Melting Point 845℃
Boiling Point 1484℃
Vapour 10 mm Hg @ 983 deg C
Solubility Decomposes in water, alcohol and acids to H2
Color/Form Lustrous, silver-white surface (when freshly cut); face-centered cubic structure below 300 deg C; acquires bluish-gray tarnish on exposure to moist air
Silvery-white metal
Stability Stable, but reacts with water to release hydrogen and produce calcium hydroxide. Incompatible with strong oxidizing agents, alcohols, moisture.
HS Code 2805120090
Storage temp water-free area
Hydroxide CAS No: 14280-30-9 MF: HO
Density g/cm3
Boiling Point 100°Cat760mmHg
Vapour 24.5mmHg at 25°C
Flash Point °C
1305-62-0 Related Suppilers
  • 1YR hebei crovell biotech co. ltd Country/Region:China Product Name:QUality Tope Quality food grade industrial grade Hydrated Lime Ca(OH)2 Calcium Hydroxide hsca price white powder cas 1305-62-0 Update Time:Jun 08 2021 Main products:Cosmetic Raw Materials,solvents,etc. Inquire
  • 2YRS Jilin Tely Imp & Exp Co., Ltd Country/Region:China Product Name:Calcium hydroxide CAS No.: 1305-62-0 Update Time:Nov 27 2020 Main products:Pharmaceutical raw materials,Chemical reagent, Food aditives,Plant ExtracPharmaceutical and pesticide intermediates. Inquire
  • 1YR Amitychem Corporation Country/Region:China Product Name:Factory Supply Calcium Hydroxide Update Time:Mar 09 2021 Main products:Manufacture & Supply Biopharm Chemical, Specialty Chemical, PetroChemical. Inquire
  • 1YR HANGZHOU CLAP TECHNOLOGY CO.,LTD Country/Region:China Product Name:Calcium hydroxide Update Time:Dec 26 2020 Main products:API,Pharmaceutical intermediates, food additives, plant extracts,cosmetics,fine chemicals,reagents Inquire
